Bird
Date:  4-27-2011
Number of Hours:  4.00
Manual Reference:  Pg.7-4, Dwg.9A, 17
Brief Description:  Sizing upper wing skin holes
Drilled upper, inner and outer skins with wing walk doubler to final size. I used clecoes every 3rd hole on the entire skins and spars to make sure I had no movement. I also dropped my plumb-bobs at the inner and outer most ribs and took measurements to the rear spar. It measured exactly 2 5/8 inches on both. I was pleased with that, knowing its perfectly straight before I drilled holes to final size. I used boelube when drilling.
adding more clecoes
adding more clecoes
lotsa drilling, used boelube
