Moved all the parts except wing skins into the shop, and organized them. Left wing skins in original crate and put cover back on to protect them for now. Began construction of wings. Attached tank attach nutplates on spar dwg16 detail 16a, six locations. Drilled and countersunk all holes for nutplates on the rest of the spars for fuel tank attachchment (top and bottom) and for inspection plates on bottom of spars. After countersinking, used a q-tip to prime the countersunk holes with self-etching primer. Primed k100-8 and k1000-6 nutplates.
