Installed the vent tubing in between the naca and the vent on the instrument panel. Fabricated the fuel line in between the fuel pump and the firewall. Installed fuel line with bulkhead fitting. Installed brake line fittings on both master cylinders. Installed both flexible brake lines in between the master cylinders and the forward bulkhead.
