Glass is cured, removed fairing and trimmed. Reinstalled and applied coat of resin and glass bead mix as a filler. Let cure. Taped the intersection fairing edges and installed on the wheel fairing. Put two coats of resin with glass beads to build a lip on the wheel fairings around the intersection fairing.
