Fabricated a new throttle handle, made provisions in it for a rocker switch for elevator trim. Installed trim indicator on instrument panelFabricated a ground buss using a 25 pin d-sub male connector. This will be used for avionics grounds and switch grounds for the vertical power. Gathered wire and connectors for intercom, downloads dwg's for mgl v-6 radio.
