Mounted fuel valve onto bracket. Installed in fuselage. Measured and fabricated L/H and R/H fuel lines. Fabricated fuel line to fuel pump from valve. Removed valve and final installed fittings with permatex #2. Reinstalled fuel valve and torqued L/H and R/H fuel lines. Installed adel clamps on the R/H fuel line. Cut and flared lines that go to each tank at 3 1/4 in. from fuselage side. Note: fuel line from vavle to pump is not torqued or completed, waiting for the pump.
