Removed vertical stab. Installed elevators with proper spacers and temporary bolted. Aligned elevators and drilled elevator horns. Installed push pull tube and clamped elevators in neutral. Adjusted push pull tube to make control stick vertical with fuselage. Inspected control system for proper clearance everywhere. OK.
