Double checked measurements again. Drilled front and rear holes for stab mount. Installed bolts, and double checked measurements again. Measurments are perfect!. Fitted vertical stab and bracket and spacer. Set measurments and double checked. Drilled all holes for vertical stab., deburred and bolted vertical stab.
