Assembled rudder pedal angles, brackets, pedals and brake cylinders. Fabricated teflon thrust washers and installed on assembly. Placed assembly in front fuselage floor board in order to lay out rivet patterns and countersink existing rivet holes on firewall angle as necessary. Decided to take my time and do this step before I rivet the front side skins for ease of access.
