Bird
Date:  9-1-2011
Number of Hours:  6.00
Manual Reference:  Pg.12,13 DWG 65
Brief Description:  seat rib assembly
Drilled all holes for bottom skins to seat rib assembly. Broke edge for the seam between the two. Broke edge on each side where the side skin meets these bottom skins. Deburred holes. Dimpled both bottom seat skins and primed contact areas. Dimpled the left hand seat ribs and prepared for primer.
