Installed fuel vent line and capacitive fuel plates and wired in. Installed and sealed bnc fuel connector. Torqued and sealed fuel vent line to fitting, sealed wiring connectors with sealant. Check wiring for continuity and isolation. OK. Installed rear tank baffle with sealant and clecoes. Riveted the tank mounting brackets to rear baffle and rear rib flanges. Sealed rivet heads on them.
