Clecoed bottom skins making sure that the outer skin overlaps the inner skin, like the top skins are. Drilled all the holes in bottom skins to final size. Double checked plumbbobs before I started drilling, Measurements still ok and the top skins are still clecoed on when I drilled the bottom skins. I drew two lines on bottom outer skin to intersect where the tie down hole will be in the leading edge skin.
