Brief Description: fit elevator to horizontal stabilizer
Fitted elevators onto horiz. stab. Checked for good movement. OK. Drilled elevator horns and bolted center hinge point, checked for good movement from –20 to + 30 degrees. Very good. Ok. Fitted fiberglass end pieces on stab and elevators. Final drilled, dimpled and machine countersunk. Riveted R/H fiberglass tip to elevator. Prepared fiberglass stab tips for glassing closed.
