Brief Description: Dimple, counter sink, and bevel parts on under str
Another good day with no mistakes.......Tomorrow I should be able to get all of the left elevator parts except fot the trim tab, primmed.
I used my pnuematic squeezer to dimple all of the parts. Then I set up the counter sink tool and used it to counter sink the top of 606...make sure to countersink the top and dimple the bottom!!!
For the other holes in the 702 and aft facing 606 I used my speed deburring handle to slowly countersink these holes.......a handfull of turns, test fit a rivet and another turn or three, test fit and so on.
To finish off the day I used the scotch wheel to bevel the edges of 713 per the instructions.....
using the countersink bit to countersink the TOP of 606
Speed deburring handle to counter sink these holes
