Brief Description: Riveted on skin and rolled leading edge
Had a lond day in the shop today. I started off by riveting on the skin with my squeezer.....went wll with no hand ups. The only sketchy part was getting the rivets at the fathest poing on the trailing edge. At first I thought there was no way, even with my no hole yoke. It did work....not sure how, but it did.
I then took up Dan Hortons advice and used the 3/4" conduit with J bolt to hold everything down nice and tight. It worked great as well. there are no creases in the bent at all.
using my squeezer to rivet on the skin
3/4" conduit with "J" bolts to roll the edge
The edge all rolled and clecoed....worked GREAT!!!
