Brief Description: Cleaned up scotchweld and riveted 606
Took out all of the clecoes today and cleaned up the holes from excess scotchweld. and set all of the rivets in the riblet and 606 spar (be sure not to set the rivets in the top of the spar at this time)
Everything went well. I will try to fill the pop rivets with some JB Weld and sand smooth to look more like a solid rivet.
I was going to start on the trim tab today, but I decided to wait till I was fresh before I start that task.....I may come back to it tonight.
Some pop rivets used here. Ill fill them with some JB Weld and you will never know
