Brief Description: Bottom rib, fabricate shim, cleco on bottome rudde
I have got to get better pictures of my progress!!!!!!!!!!!!!!! I promise it will get better. I clecoed the 904 to the bottom 902 spar and enlarge the hole with a reamer.....worked way better than a drill bit. then I fabricated the 917 shim and fit everything together to make sure the fit was good.
