Marks Rans Courier Project
Date:  7-12-2009
Brief Description:  Install gear leg fairings
I had Mike and Sean assist with installing the gear-leg fairings. To install the fairings I had to jack the plane up and remove the brake calipers and wheels to get access to the metal tab that fastens the bottom of the fairings to the bottom end of the gear leg.
The fairings went on without too much fuss. Sean re-installed the wheel/brake assemblies, and Mike cleco'd the fairing in place, then installed the avex rivets that hold them for the long-haul.
