Marks Rans Courier Project
Date:  5-18-2008
Brief Description:  Motor mounts installation
I installed the rear motor mount bolts. I had temporary bolts in place, but due to mis-alignment of the motor mount with the fuselage the threads on the bolts took a beating and I wanted to replace them with new bolts.
This process was slow and difficult. The motor mount does not perfectly align with the fuselage, so it is difficult to get the bolts in place without damaging the threads. I had to experiment with inserting the bolts in varying order, and with cajoling the motor mount into position to get the bolts inserted and in good condition. This should probably be a two-man job, but I generally work alone so I did it the hard way.
