Brief Description: Fit elevator yoke to horns, wiring on pitch trim
Michael assisted in fitting the elevator attachment yoke to the elevator horns. The yoke is made of aluminum tubing and needed some slight adjustment to match the horns.
I then started wiring the pitch trim at the control servo. After attaching all the wires I tested the system. The trim servo works appropriately, but the indicator does not indicate. Tomorrow will be trouble-shooting that problem.
