Began installation of the control surfaces on the left wing. I installed the hinges, then fitted the aileron and flap to the wing, installed both, then adjusted the hinge bolts per the manual. Several of the hinges needed shimming with thin washers to acheive a nice uniform fit.
Susie assisted with installing the wiring loom into the trailing edge spar as well.
