Today was more fitting and installation of the aileron & flap gap seals on the right wing. I have all of the seals installed except the most outboard one, and I will need to finish fit the wing-tip unit prior to fitting that seal, so....
Began fitting the wing tip unit on the right wing. I have a photo attached that shows the tip fitting in progress. I still have some more trimming to do, and am basically sneaking up on a good fit to avoid cutting away too much material.
