Marks Rans Courier Project
Date:  1-25-2009
Number of Hours:  6.00
Brief Description:  Headphone jacks, Elevator trim etc
I installed the headphone jacks and the co-pilot's PTT button/switch into the two mounting plates, then installed the plates adjacent to the two seats. I looped extra wire for all the leads and secured the loops below the mounting plates. I felt having extra wire was a good hedge in the event I need to modify the headset wiring at some later time.
I also started on the elevator trim, running the 5-wire bundle and threading the wire out of the left-rear fuselage side adjacent to the horizontal stabilizer. The wire exits the fuselage through an embedded grommet, then enters the horizontal stabilizer through another grommet. The wire routes through the stabilizer and exits through a small fairing, then goes into the fairing for the trim servo and control rod.
