Marks Rans Courier Project
S7S
engine re-configuration
The first photo depicts the drip cup installed, the throttle cable bracket installed, and the choke cable bracket/tube installed.
The second photo shows the left carb with the drip cup, the thottle cable bracket and the choke cable bracket/tube installed.
The third photo shows the cooling fins ground away to clear the motor mount bolt. Only a little material needs to be removed.
drip cup, throttle cable bracket and choke cable bracket
Drip cup, relocated throttle spring, and cable mounts
S7S Home
1046
Cowling
Doors
Electrical system
25
74
First Flight
256
Instrument Panel
Mains, wheel/brake
Rigging
Torque tube assembly
Windshield & Skylite
199
