Brief Description: Installing brake cylinders and hoses
I worked on the installation of the brake master cylinders and brake lines. The brake lines are a translucent plastic 1/4" OD line that is held with pressure fittings. FIguring out how to route the lines seems to be a trial and error process. I looked at a number of photos that I have taken of other S7's, but they all seem to have different components or different placement of the parking brake maniford. I also found that I was miissing one of the compression fitting from one of the 90 degree elbows so I am waiting for one to arrive from Kansas.
