I started the assembly of the elevator yoke/aft push/pull tube unit. The instructions should have indicated to install the end-fittings on the two yoke tubes prior to fitting the tubes/fitting into the push/pull tube as once fitted to the push/pull tube, you cannot get to two of the eight holes for the rivets attaching the threaded fittings at the aft end.
