I fitted the tail wheel spring to the saddle/channel on the tail wheel assembly and bolted it in place. As suggested in the manual I had to hand-file the portion of the spring that sits in the saddle. The main problem appeared to be the thickness of the power-coating, but I had to file some metal from the sides of the spring to get it to seat fully in the saddle.
