Brief Description: Page 516 Made a Weight Mount Shelf
August 8 2015
I was using plastic jugs and bottles of water laying in the nose for ballast, but a bounced water landing, jostled them enough to break the fiberglass covered wood furring strip I was using to mount the Contactors and Main Fuse, off the inside of the Hull. I repaired that, and decided not to put the jugs back. I made a shelf to hold Barbell Weights to use for ballast to keep things from bouncing around.
2 Antifreeze jugs
4 Water bottles
Weight shelf will hold 4 to 6 4.5 lbs Orbatron plastic covered cement weights
