TAB Aircraft LLC Web Site
Date:  8-8-2015
Number of Hours:  0.00
Manual Reference:  N/A
Brief Description:  Page 516 Made a Weight Mount Shelf
August 8 2015
I was using plastic jugs and bottles of water laying in the nose for ballast, but a bounced water landing, jostled them enough to break the fiberglass covered wood furring strip I was using to mount the Contactors and Main Fuse, off the inside of the Hull.
I repaired that, and decided not to put the jugs back.
I made a shelf to hold Barbell Weights to use for ballast to keep things from bouncing around.
2 Antifreeze jugs
2 Antifreeze jugs
4 Water bottles
4 Water bottles
Weight shelf will hold 4 to 6  4.5 lbs Orbatron plastic covered cement weights
