Section 23 Installing Trim Tab Manual Ref: 6.1 to 6.3
Because the Viking Engine spins the opposite direction from the Rotax, The Trim Tab needed to go on the right side of the Rudder and bend to the right side. I clamped the trim tab at the bend and heated the plastic till it could be bent the opposite direction. I then installed it on the rudder.
