Brief Description: Retro fit tank straps and bolts
earler I installed rubber strips to protect the aluminum tank from steel straps. in doing this the origonal bolts would not fit so i ordered longer bolts and 1/4 id steel tube to make new Spacers. While orderind new bolts i decided to get drilled bolts and castle nuts so i coulduse cotter pins to lock the bolts from working loose due to virbration.
