Dans T-51 Construction Log
Date:  4-14-2015
Manual Reference:  t51-13-ins-1976-A
Brief Description:  Retro fit tank straps and bolts
earler I installed rubber strips to protect the aluminum tank from steel straps.
in doing this the origonal bolts would not fit so i ordered longer bolts and 1/4 id steel tube to make new Spacers.
While orderind new bolts i decided to get drilled bolts and castle nuts so i coulduse cotter pins to lock the bolts from working loose due to virbration.
Making 1/4
Making 1/4" x5/8" spacers
Spacers inslltaled
Spacers inslltaled
New cotter pin in castle nut.
