This will be a long and tedious job to fill pin holes on the cowling. I decided to squeegee on a thin coat of epoxy layer today (not diluted), followed by sanding and another layer of epoxy coat and some more sanding. Today I applied the resin-hardener mixture. Also coated with epoxy the inside of the gear leg fairings to prevent dirt (oil, etc) soaking into the fiberglass.
