Check autopilot servo travel for both servos to make sure they are not over center. They look OK. The aileron travel is 1 3/8" and the elevator is 2 1/8". I installed the servo stop on the elevator earlier, but the arm does not touch this stop at its extreme position. I checked the aileron stop, but is was nat needed since the arm does not come close enough to touch the stop at the extreme position. Found that the dimmer no longer works. When I move the connector it shows intermittent light AT the ADI. There must be a short on the PC board. Removed and ordered a new unit.
