I haven't look at the wiring for a long time and before closing the upper forward skin I will review both the electrical and the avionics systems. Easy to forget this stuff. Grounded the OAT probe. Took a lot of time to label and pull this wire back to the central ground block on the inside of the firewall. Secure autopilot connector at wing root (inside cockpit) with screws, lock washers and nut.
