Came out with Bob Sevier (son-in-law) and charged up the break system with break fluid (Aeroshell Fluid 41 Mill-PRF-5606). Purchase an 1/8 Connector (pipe thread) for the fluid reservoir with a 1/4" hose connector and a 1/4" hose. Bob pulled vacuum at the break bib while I pured brake fluid into the tube and into the break fluid reservoir. At the same time we pumped the breaks. Ended up with very firm breaks and to very small bubles. Later will try to purge these from the lines (actually they migrated up and diappeared for the lines.
