Reassemble the map box for the back cover using the screws for the back plate and clecos for the angle supports along the back top and bottom of the box. The back plate is screwed to the angle supports and the angle support will be riveted to the box along the back top of the box. Counter sink the rivet holes on the box. Rivet the angle support using blind rivets. Finish checking all the Service Bulletin compliance.
