Drill the support legs for the base using #12 drill and install bolts, washers, and nuts. The top of the support legs will be attached to the clamp I made earlier by #10 bolts (notice the blue tape that temporaily holds the support legs by the clamps). I will mark the location of these bolts on the clamp using a #40 drill bit just marking the clamp without going all the way through.
