Brief Description: Pull wires from Exp Bus to Power Connectors
We have visited my sister in Toronto from the 12th to the 20th and returned with a bad cold. Did not start with the airplane work until the 24th. Pull the power wires from the Exp Bus tray to the power connectors and install the female pins in each connector. The wires are separated into three bundles for three connectors. The right connector (as shown on the picture) contains the avionics power wires (6 wires). The middle connector contains some miscellaneous power wires (5 wires). The left connector contains the power wires from the swich panel (8 wires). All this is clearly documented in the Exp Bus portion of my construction manuals. This arrangement is quite clean and provide a good way of changing brakers between devices if necessary. All this work actually took two days the 25th and the 26th of August.
