After some time of trying to figure out how to route the oil hose to the oil cooler (lower hose) I decided to take off the prop control line bracket since no matter what I came up with it was in the way. I also oriented the hose connector, at the engine side, down. This was a really miserable long job. No room. Without the bracket installed I was able to tighten up the connectors for the oil hose both at the oil cooler and the engine connector.
