Brief Description: Fit Part 2, left front air inlet floor.
Fitted the left front air inlet floor. Cut Part 2S and Part 2R as per plans and layed out and drilled the rivet holes through Part 2, Part 2R. Fitted Part 14 to the engine block. I marked the location of Part 14 on the engine block (verical top position) and used a transparent velum piece to locate the screw hole by drawing the screw hole on the velum (the velum was cut to the same shape as Part 14). Then I transfered this location to Part 14. This worked out really good, right on the money. Installed the two platenus on Part 14 and drilled the screw holes on Part 2. It took a lot of cutting fiting and bending to make the floor look good. I still have to install Part 13, Part F1A and Part F1B.
