Drill hole and install VA-170 for IE VMP35manifold pressure gauge in firewall as per drawing (OP-33). Remove the plug in the pressure port at the bottom left corner of #3 cylinder and install the AN816-4D fitting supplied wit the IE-VMP kit Install the VA119 hose.
