Brief Description: Recognition light on bottom rudder tip
Drill the holes for the rudder bottom tip. Install platenuts. Install recognition light on the bottom rudder tip. For the two bolts I used 1/4" deep nuts cemented into the fiberglass tip. I felt this would give me a more solid anchor point. It was a slow process, but finally everything worked out OK. Will have to do some more fiberglass fill for the two nuts to anchor them better and fill a couple of tiny holes on the tip skin. Will go to Hungary for 15-20 days.
