This has been a long and tedious job. Also made some time consuming small mistakes, like drilling the wrong holes for the platenuts. As I indicated in an earlier post I decided to use one hinge eyelet for each terminator. To make it easier for myself to remove the cowling the top hinge on the top cowling is terminated on top of the cowling. This way I don't need to use the oil filler door. The two bottom hinges on the bottom cowl is terminated just below the out side edges of the cowl. Very easy to remove the pin. The pitures show what I did.
