Brief Description: Glue and rivet hinge to upper cowling
Cleaned and sanded (#80 paper) both the hinges and the cowling along the two sides and the rear. Mix the T88 glue and spread along the the area where the hinge is riveted to the cowl. Cleco the hinges onto the cowling using every other rivet hole. Insert the rivets and set the rivets with the squeezer. Each cleco is dipped into petroleum jelly. This way it is easy to clean the clecos the glue does not stick. Removed the remaining clecos and finish riveting.
