These steps are necessary before the engine is hung. Install Prop Governor and governor cable bracket. I did not yet torque the bolts. Waiting for star washers. This will be a very difficult job. Scott at VAN's told me that the only way to do this is by feel. Clamp a bolt into a wise, install the nut and torque it to 100 in/lbs. Feel it and do the same thing using an open end wrench on the four nuts.
