Assemble the attach hardware for the throttle and mixture cable ends. Fasten the screws for then F-982 E cover plate. After realizing that there are two sharp edges close to where the cable bundle comes through, I will have to remove this plate and install a rubber edge to protect the cables. Probably not needed, but it is safer this way. Work on the carburetor FAB box. I am uncomfortable sealing the gap between the carb and the upper air filter plate with RTV. Decided not to do it.
