Finally, after the paint job was done, I decided to install the Exit Air Attach Bracket. To install the bolt and the nut on the firewall side was relatively easy since access was if not open it was manageable for initially starting the nut. To tighten the nut I had to turn 1/4 turn at a time, so it was a lengthily process. Next I started on the gear leg side where the two nuts had very little room for access. Once I was able to start the nut I could put a small thin wrench on the nut and was able to turn the bolt to tighten the assembly. To start the nut I used a double sided tape on my index finger stuck the nut to the tape and while I was holding the nut in place turned the bolt until the nut caught on. What a slow struggle, but it worked.
