Some time ago I made the Exit Air Attach Bracket, but did not rivet it together. Today I fitted it in place, made sure that the holes for the bolts line up. All is well, although there is very limited space to work in. I riveted the assembly together and test fitted again. To install the nut on the landing gear side will be very difficult. Maybe I can come up with a tool to hold the nuts in place white I try to start them. In the picture the Bracket is loosely attached to the firewall. One can see the tight spot at the gear leg attack point.
