Brief Description: Right wingtip, Engine hose, Fuel totalizer
Wasn't a very productive day. I purchased a few plastic nuts(6-32) since one of the COM antenna tiedown nuts was missing. Installed this nut as per picture. The threaded rod that holds the engine baffle around the cylinders had to be protected around the oil line for possible vibration problems. Wrapped this rod with high temp Tape (500 degrees). Thigten the nut at the fuel outlet on the fuel pump. Review fuel totalizer hookup.
